Hitachi Service Codes
Discussion in 'Plasma TVs Forum' started by Welly123, Dec 29, 2004.
  1. Welly123
    Welly123
    May 18, 2002
    263
    +5
    Hi All,
    Does anyone have the service codes (access to the service menu) for the Hitachi 42PD5200?
    Thanks in advance for any positive responses...
    Regards
  2. monsteria
    monsteria
    Mar 14, 2005
    29
    3
    Did you get anywhere with finding a service code for Hitachi plasma?
  3. Welly123
    Welly123
    May 18, 2002
    263
    +5
    I did obtain the code to enter service mode but as it turns out, not a lot of use. It did however enable me to switch on the RS232 interface but the display does not appear to understand RC5 codes through the serial interface.
    If you PM me with your e-mail address I can send you the information I eventually received from Hitachi....
    Regards
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Be very careful ! The last person on here who played with the Hitachi service codes ended up switching off his remote control :eek:
    (Not me, I might add).
  5. Welly123
    Welly123
    May 18, 2002
    263
    +5
    Yep. That is noted on the documention from Hitachi. The serial port will lock-out the remote function when in use, where the serial port gets a "open" but no "close" command the remote will remain locked.
    Regards
  6. efendi
    efendi
    Jan 5, 2005
    65
    Yes,
    that person really switched off his RC. But in the same time he promised to fix that and come back here with that fix - and here it is for your pleasure :D :
    In the Service menu, change the register 175 from "0" to "1" - it turns the RC on again and everything's OK :smashin:
    TBH, I have a few more hints in this regard, but no time to post it at whole
    Petr
  7. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Now, if someone can find the register to make the TV display 720p/50, I'll sit up and take notice :D
  8. Welly123
    Welly123
    May 18, 2002
    263
    +5
    It's called "iScan HD+".... works a treat.
  9. Olimatou
    Olimatou
    Here is a link for RS232c application notes from Hitachi Europe. The right bit settings to enable or disable the RS232c is on the register location 180 - 0:disable 1:enable .
    Link to Hitachi's correct document (Right clic + SaveAs)
    To enter the service menu on plasma panels for :
    • 32PD5200 / 5300
    • 37PD5200 / 5300
    • 42PD5000 / 5100 / 5200 / 5300
    Using the buttons on the plasma :
    1. Switch into stand-by mode
    2. Press Position Down and Input buttons.
    3. While holding these buttons, press and hold Power On button until the Service Menu appears (5 sec)
  10. Olimatou
    Olimatou
