H
Hagforce
Hello!
I got the PMA400e plasma screen.
At first I was not satisfied with the PQ, but after some days of tweaking I think it its great.
The initial settings must be crap?
I found that the contrast is best set at around 40
Initial this was sett too full (127)
Way isnt the screen settings good at default, if it was tweaked in the first place it would lock better in the showroom
All the filters and **** is also turned on, and some of them really crapes up the image.
Is all this impressions just me
Or do you have the same view on things.
If some of you that got some test dvds and has set your screen from these parameters would come with an input on this that would be great!
Maybe post your settings
Sorry about the bad English, I`m from Norway
