Quantcast
Hitachi pma400e prog scan problem
ridd
Hi.
I have a problem with image tearing on my panel when using a dvd player in progressive scan.
I have used two different players so i know it is the panel.
It doesnt matter if i use ntsc or pal, or if i use the videoboard component connections or the d-sub component connection.
It happens alot on fast scene changes or on a slow scene the picture kinda tears from one of the top corners. ITs quite similar to the tearing effect you can get when you dissable v-sync on a pc's video card.
based on this i have looked around the panels menus for something to allow me to change its refresh rate but have not found anything.
Can anyone help ???
Mark
