Hitachi PMA400E Issue
Discussion in 'Plasma TVs Forum' started by zorg2000k, Jul 14, 2003.
  1. zorg2000k
    zorg2000k
    Jun 5, 2003
    361
    +15
    Here's my problem. :(
    I'm running my screen all through component connections. Sky and Kiss DVD player jump through.
    After about an hour the picture starts to jump not all the time though. When I call the Sky menu up you can see this happen very easliy. I run the rgb scart output into a Keene RGB2component Y,G,B and then to the screen.
    Any chance its this box and not the screen.
    Should also point out that if I call up the plasma menu it doesnt jump but the sky menu in the background does, same for dvd source as well.
    Any help much appreciated.
    Zorg
  2. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,196
    n/a
    +283
    zorg2000k,
    I had a similer problem, but it would only jump if i watch R1 DVD's so i had the video card changed, this solved the problem :)
    In the setup menu make sure the LINE INTP IS SET TO OFF
    hope this helps:smashin:
    dvd
  3. The Editor
    The Editor
    Zorg,
    I had a very similar problem - It appears the Hitachi's are VERY touchy on the quality of sync signals they are sent.
    The way I solved it was to run a dedicated component cable direct from my DVD player into Video 2 and everything else (via a JS Technologies RGB to component converter) into RGB 1 configured to accept component on that input (via a component to 15 pin d-sub)
    Problem solved !!
    I've thrown most things at it via that route including some dodgy signals from some obscure satellites via a motorised sat system and it's rock solid ....
    Hope this helps
    The Editor
  4. zorg2000k
    zorg2000k
    Jun 5, 2003
    361
    +15
    Hi again,
    Well changed my Keene RGB2Component convertor to an J&S Technologies RGB2 and hoped that was my problem fixed.
    Unfortunatley I still have the same problem, jumping screen. When I change to composite video in with the same source the jumping screen stops.
    Do you think the video board is faulty and needs replaced ?
    TIA
    Zorg
  5. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,196
    n/a
    +283
    zorg,
    yes, i would change the video board.
    dvd
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    It's true the screen is very picky, had one or 2 panny's with the same kind of issues though, cured with new video board, but nver cured a hitachi sorry to say. Another reason I don't like them, shame when so much else goes in their favour.
  7. JH4
    JH4
    May 6, 2003
    2,402
    63
    +244
    I agree with "The Editor". Don't think you will have a problem if you use a JS RGB - Component convertor. $ky and R1 DVD's should be fine.
    Regards.
  8. zorg2000k
    zorg2000k
    Jun 5, 2003
    361
    +15
    Thanks Guys,
    Have spoken to Richersounds and they are sending a replacement screen for me this week, all going well should be ok now :zonked:
    Zorg
  9. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,196
    n/a
    +283
    zorg,
    :smashin:
    dvd
