Hitachi plasma ordered.... question
Discussion in 'Plasma TVs Forum' started by Pheedbak, Jan 20, 2004.
  1. Pheedbak
    Pheedbak
    Jan 19, 2004
    47
    Hi all,
    Firstly many thanks for all the posts etc ive read from all of you to help me narrow down my plasma choice. In the end i deceided i couldnt justify spending over 3 grand so went for the hitachi 42 incher from currys plus discount (thanks whoever started that one!) so now im just w8ing for delivery.
    My question is a simple one how long is the cable from the media box to the plasma .... i need to run it across the room.
    Also is 99 quid from argos the cheapest the wall mount comes ?
    Many thanks
    Phil
  2. Elvis
    Elvis
    Hitachi do a longer cable that you can buy - at extra cost- I think it's about 10m long. The one in the box won't stretch across a room (unless you live in a shoe box), it's about 1.5m.
    £99 for a proper hitachi wall mount sounds like a bargain to me.
  3. RichardJ
    RichardJ
    Jan 27, 2003
    Shropshire
    +6
    The cable from the media box is only around 2m so you'll need the 10m cable. It doesn't come cheap though, the cheapest I managed to get it was £180.99 from Unbeatable and is a special order item.
    The good news is that the Hitachi wall mount is only £87.99 from there though.
  4. Pheedbak
    Pheedbak
    Jan 19, 2004
    47
    thanks for the replies ill get onto unbeatable then :)
    Phil
  5. s8ngy
    s8ngy
    You can make your own cable for the 42pd3000 if you buy a DVI cable (£15 for 5m) and buy two 8 pin mini din plugs from maplin with 5 metres of individually shielded 8 core cable (£10) solder the mini din's pin-to-pin (need to be good with a soldering iron) and for a total of £25 you get a good working cable. Add another £12 if you want to make a 10m version.
    You need to use good shielded cable on the 8pin or you will get digital chatter through the speakers at higer volumes.
