Hitachi Plasma CL32PD2100 & 32PD3000
Discussion in 'Plasma TVs Forum' started by spencer3958, Aug 31, 2004.
  1. spencer3958
    spencer3958
    Can anybody comment on these plamas both of which are retailing around the £1000 mark. Would they be better than an equivalent priced 26" LCD
    David
  2. kitschcamp
    kitschcamp
    Sep 13, 2004
    256
    Australia
    +65
    I just got the 32PD3000 at the weekend in the Powerhouse sale. The reason for my choice, as much as anything, was 2 RGB scarts, 1 S-Video scart and component and S-video connections, plus the PC connection meaning I could connect everything up I needed to without popping down to Keene's for lots of convertors and connectors.
    So far I'm incredibly impressed with it.
  3. Judgey
    Judgey
    Apr 12, 2004
    56
    11
    London
    +9
    I have the 42PD3000, which I beleive is identical bar the size, and I am very happy with it.
    It needs to be set-up properly to get the best out of it, but once thats done, it gives very good results.
    The price sounds good also.
  4. Big Al
    Big Al
    Jul 13, 2000
    247
    Sandhurst Berkshire UK
    No problems with our 32PD300, Just great pictures and good sound.
    At that price consider it a bargin.
    Regards
    Big Al
  5. spencer3958
    spencer3958
    What is the powerhouse price please?
  6. David
    David
    Nov 26, 2002
    221
    16
    London
    I'm thinking of getting one too as Richer Sounds has it for £999 at the moment. What did you mean by setting it up properly. Is this something I could do myself? I read somewhere that some early versions had a greenish colour cast. Is that part of the problem?
    Thanks in anticipation
  7. Judgey
    Judgey
    Apr 12, 2004
    56
    11
    London
    +9
    What I did was to use the THX Setup Utility found on certain DVD's (Finding Nemo is one) in conjunction with some THX Blue Goggles (Like cardboard 3D Glasses, but with blue filters) which are available from THX.com for $5 inc shipping.
    Once you have made all the adjustments, the picture really does improve across the board. The one thing most manufacturers seem to do, is set the contrast/colour/brightness at a default level that will induce retina burn on the viewer. This causes colour crawl and other picture problems on some sources.
    Can't say my set has ever suffered from a greenish hue though.
    Hope that is helpful.
    Judgey
  8. David
    David
    Nov 26, 2002
    221
    16
    London
    Yes thanks, this is helpful. I will look out for a DVD with this utility. Do you get the glasses free with the DVD? I would want to connect a DVD (preferably by Scart in RGB mode), a freeview box (probably S-Video scart) and an S-VHS recorder (S-Video Scart). Do you know whether this will be possible.
  9. Judgey
    Judgey
    Apr 12, 2004
    56
    11
    London
    +9
    Shouldn't be any problem. The 42PD3000 (Assume 32PD3000 is the same) has excellent connections, inc 3 scarts ( from memory i think Scart 1 is S-Video and scart 2 & 3 are RGB), component inputs and a vga input. I am running a freeview box, DVD Recorder and a PC into mine.
    The THX glasses need to be ordered from www.thx.com and they charge $5 which is just for postage. They take a week or two to arrive.
