Hitachi plasma and progressive scan
Discussion in 'Plasma TVs Forum' started by pauwoo, Mar 18, 2005.
  1. pauwoo
    pauwoo
    Mar 12, 2005
    I have a Hitachi plasma 42DP5200 and i also have a Denon 2900 DVD.
    I have just gotten myself a component lead.
    I connected one end of the lead to AV1 on the screen which is supposed to be for component, turned on the progressive scan on my DVD and changed the video output to RGB, put in a DVD and it wouldn't spin up my DVD.
    I changed the video output back to s-video and it played fine.
    I moved the connections from AV1 to AV2 on my screen which is also a component feed and changed the output on the player to RGB and it now plays fine.
    Does anyone have any idea why it wouldn't work in the original connection?
  2. johndon
    johndon
    Feb 3, 2002
    1,989
    63
    +122
    No idea why it didn't work but you'll probably find that progressive scam makes no difference on the Hitachi as it's an interlaced screen.
    I did a lot of testing on my 5300 with an Arcam DV79 DVD player switching between progressive and non progressive. My wife (who knows nothing about prog scan) did the viewing and preffered the non progressive picture.
    John
  3. DaveRichardson
    DaveRichardson
    I don't know about the set up of your Denon DVD player, but the Hitachi inputs are :
    AV1 component input is Y Pb Pr ie not RGB
    Av2 input can be RGB or YPbPr (it should switch automatically).
    It sounds like you are sending an RGB signal
    Regards
    Dave
  4. efendi
    efendi
    Jan 5, 2005
    65
    got a 42PD5200 and the DENON 2900 too, going progressive (component) to AV1 and it's working fine... Be sure you connected the cables properly. BTW, I've also found little to no difference between progressive and interlaced signal, except the menus from DVD having less line flickering on progressive, so I've left it this way. Had not much time for testing, though...
    Petr
  5. efendi
    efendi
    Jan 5, 2005
    65
    IMO there is the possibility to select the RGB output thru DENON's scart output only, not component :)
    Petr
  6. efendi
    efendi
    Jan 5, 2005
    65
    Also, take a look at HITACHI's menu, there is a part of it called "input setup" or so, and there you'll find the preferred input signal type for each input... Look at AV1, it should be "auto" or "component" IMHO
    Petr
