hitachi pjtx10
Discussion in 'Projectors, Screens & Video Processors' started by jamiev, Jan 4, 2004.
  1. jamiev
    jamiev
    Jan 4, 2004
    923
    +35
    hi, i am thinking of purchasing the above projector, what is the best way of connecting it to my amp/dvd system and how much (approx) will the cables cost? lenght required is about 8 meters. it will be going in the living room and i was thinking of buying a portabe screen on a stand. are these any good?
    thanks
  2. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    Use a dvd player with componant out, you may not need a progressive scan player as the pjtx10 has its own de-interlacer.
    For sky/freeview try at least using s-video.
    email www.tmfsolutions.co.uk for a quote on componant and s-video cables, they use vanne damme which I use and seem pretty good.
    I payed approx £45 for 10 metres of componant cable.
    As for screens, if you want portable you could go for a pull up screen which comes with its own case, not sure who sells these though.
  3. jamiev
    jamiev
    Jan 4, 2004
    923
    +35
    ok thanks
    the dvd player is cambridge audio 53!!
  4. jamiev
    jamiev
    Jan 4, 2004
    923
    +35
    the dvd player has got s-video, so i presume the connection would be s-video to s-video? would this be the best way for picture quality?
    thanks
  5. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    That would be ok for starters, but you are best looking at getting a componant dvd player to get somewhere near the the best out of a projector.
    I started of with s-video to my projector which was ok, but found a large jump in picture quality when I upgraded to componant out.
  6. jamiev
    jamiev
    Jan 4, 2004
    923
    +35
    ok thanks,
    my dvd player has got component "Cb, Y and Cr", what do these mean? how much would these cables cost?
  7. jamiev
    jamiev
    Jan 4, 2004
    923
    +35
    the pjtx10 has also got 3 component connections so i presume that 3 cables would link from them into my component connections on my dvd palyer? looking on the www.tmfsolutions should i get phono...hat is the difference between them? thanks
  8. scott686868
    scott686868
    def use the three component cables from the dvd to projector for best quality.
    Maplin has 10m lengths for £29.99
  9. Timh
    Timh
    Sep 14, 2000
    5,130
    Altair-4
    +266
    Have a read of the projector faq at the top of the lcd page.
    Componant cables are phono to phono.
    There's a second hand set of componant leads for sale on this forum.
    click
  10. RajUK
    RajUK
    Dec 18, 2001
    157
    Reading
    +6
    i bought a component cable, made to order, from Mark Grant from the avforums and it's great
    I use it with my pjtx10 and my sony dvpns730
    definitely check him out and tell him i recommended him
