Wondering if anyone who owns a Hitachi PJ-TX100 may be able to help me please.
I've finally upgraded to a Blu Ray DVD player (got an LG BD560), but my projector shows no image at all when I connect it up via an HDMI -> DVI-D cable. Component working fine (although you can't view HD resolution over component, it seems, due to copyright protection).
The same HDMI -> DVI-D cable, plugged into my computer screen, shows an image perfectly, and I've tried 2 different cables. So the problem presumably lies with the projector.
I've tried all the different resolution and colour settings on both the projector and the player (although 720p is what it should be) - nothing! The DVI-D input is HDCP compliant, and I get this problem on the Blu Ray menu screen as well as when I try to play Blu Rays, so it's not a copy protection issue.
Really hoping I can get this sorted as don't want to have to sink another grand on a new projector just because my old Hitachi is being difficult about HD input!
Thanks for your help.
