Hitachi PDV302
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by mworton, Sep 9, 2004.
  1. mworton
    mworton
    Mar 30, 2004
    Chafford Hundred Essex
    I have just managed to hack my PDV302. Firstly go to the setup menu, scroll across to the preferences screen. Press Display and then type 0283 and press Display again. This will bring up the region code. Set this to Region 0 and this is multiregion. Then press the setup button and then power the unit down and then back on again. It is now multiregion. Hope this helps...
  2. GilGrissom
    GilGrissom
    Sep 17, 2005
    7
    I tried this hack on the hitachi pdv313 and I xan confirm that it works as well.
    Thanks very much for your help! :thumbsup:
    GilGrissom
  3. lucilles1
    lucilles1
    I have also now tried this hack on my PDV313 and it works really well! :clap:
  4. warrpp
    warrpp
    May 20, 2007
    32
    i've lost the remote for my pdv313
    does anyone know if it can be made multi-region by using the menu on the player itself ?
