Hitachi PD7200 Sky Code!
Discussion in 'Plasma TVs Forum' started by Miander, Jul 12, 2005.
  1. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    HI chaps!
    well i have tried everything even called Sky and Hitachi!
    Well sky said that i have to call Hitachi to find the code to get it so i can change the volume
    Called Hitachi... they said that iff sky didnt give it me then its cause they havent paid for it yet ????? anyway.. im getting no joy
    anyof you got it to work!. ive only got a standard sky pace box? thanks
  2. Dave911
    Dave911
    Jan 30, 2004
    386
    28
    North Yorkshire
    +40
  3. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Ahh ta dave will give a it another go :(
  4. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    no bloody luck!
  5. peterho
    peterho
    Jan 21, 2005
    58
    east yorks
    +8
    0145 works for me on Sky+ on my 7200 but you need to press tv button and text to mute it.Sky remote wont do analogue text.
    By the way dont these plasmas throw out some heat,im sweltering typing this it will be nice and cosy in winter!
    Peter
  6. rich7237
    rich7237
    Hi mate the code in the book worked for me after a fashion, at one point the remote would not even controll sky but after a second go at putting the code in it all works fine, volume and everything. The code I used was 0145 for sky plus.
  7. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    im using standard sky!:(
  8. Dave911
    Dave911
    Jan 30, 2004
    386
    28
    North Yorkshire
    +40
    Same here - standard Sky the only thing it does not mute - it changes the sound fromn normal to matrix!!! doh - its a bugger when the phone rings :eek:
    Dave
  9. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    ok something weird
    i tried the 0145, it turned the tv off, I then tried to turn it on and i wouldnt
    then when i manually turned it on.. nothing.. but
    the sky button and power button changed the input type on av4 composite/ component or somehting like that,,
    Bloody annoying!
  10. tim k
    tim k
    using the 0145 on my sky plus box doesnt do anything for me following the select and red flash 2wice, the code, then tv. i had it working with one code that just turned the tv on and off but now nothing. oh well. i quite like the normal remote.
  11. Dave911
    Dave911
    Jan 30, 2004
    386
    28
    North Yorkshire
    +40
    This is weird!!
    The not doing the mute thing annoyed me so I thought I would try different codes. WHAT A MISTAKE :mad: it just would not work no matter what I put in. I tried the three digit codes, enetering them as per the instructions and the whole remote locked out!! It really does appear to be hit and miss.
    After pressing the green and select button together and getting the 2 flashes (which I think resets the remote) I eventually tried the code 222 - however it did not flash twice after the code was entered (none of the 3 digit ones do) I pressed the tv button and nothing happened AT ALL :eek: I tried it again left the remote alone for a few minutes - went back to it and hey presto, everything worked - mute function - channel, volume and a few others via different buttons.
    Like most things out there, their are probably different models of the remote however they all look the same - I am begining to think it is just hit & miss - sometimes you are lucky other times you are not - I just got lucky :thumbsup: Fingers crossed it stays OK I am now leaving it well alone.
    Dave
  12. Miander
    Miander
    Feb 27, 2005
    316
    Midlands
    +6
    Dave when u tried it again... what code did u use?
    and select and green resets! bonza! will give it a try this savo!
    Throw another shrimp on the barbee :smashin:
  13. Dave911
    Dave911
    Jan 30, 2004
    386
    28
    North Yorkshire
    +40
    Same code 222 - follow the instructions on the link I gave you except for the press the tv button at the end. Once you have entered the code just leave the remote for a couple of mins or so and it MAY work :hiya:
  14. wonderloaf
    wonderloaf
    Jul 5, 2005
    264
    Hampshire
    +6
    Yeah, I get the same effect. Funny thing is, I can't find a button on the Hitachi remote that does the same thing, or am I missing something :confused:
