Hitachi PD7200 and HTPC - Resolution Question
bennicklen
I currently have my HTPC connected to this plasma via a DVI cable. My gpu is a XFX 7600GS and i'm using the nvidia 91.36 drivers.
At the moment i am running in 1024 x 768 resolution and it looks really good but i want to try a higher res. Using the driver i can set to 1080i but the picture goes very flickery and unwatchable.
If i use 720p resolution then it doesn't fit the screen properly.
I've tried loads of settings and keep going back to 1024 x 768 as it is reliable and works. I would really like to get 1600 x 1200 for desktop use such as internet browsing or using word etc and use 1080/720 for films etc.
Has anybody else managed to get higher resolutions on this panel that are usable.
Do you think is it a limitation of my grapics card that i cannot do these resolutions.
I'd appreciate any comments! :lease:
Ben
