Hitachi P50t01
dave-rsvr
hi,anbody know anything about the hitachi PT5001,are they any good,they are full hd and seem pretty good price.
new to all the hd stuff any advise is welcome.
thanks
dave
bankroot
by the way...
I asked several weeks ago about this TV: how it is possible to display 1080p signal on ALiS panel (it has only 540 horizontal electrodes).
I hope the time for answer has come :)
W
Waga Waga
Some info on ALIS panels here
http://www.plasmadepot.com/plasmatv/howplasmaworks.html
"Typical plasma panels have a strip of electrodes for each horizontal row of plasma cells, while ALiS panels share an electrode strip between two rows of cells. At any given instant only half the panel's pixels are turned on. "
So because there are two rows of cells per electrode, it doubles the 540 electrodes to 1080.
shane515
search this forum or click here ;)
bankroot
I have just read pointed thread, but ...
I still have no answer to my question :confused:
PS. Waga-waga: you didn't understand my question, I know how ALiS works and how it is built.
I don't imagine: how it can display 1080p signal
camorra
the electrode pulse is double that of the input signal :cool:
though the difference is clear when feeding an alis panel an interlaced signal then a progressive one :eek:
hope this helps :hiya:
bankroot
not quite,
In my understanding an ALiS panel for displaying 1080p signal should activate every pixel in the same time (in opposite to ALiS operation theory).
How does it do it ? that is the question
Second question: why it is not possible in 9700 series ALiS panel ????
I suppouse the mystery is in the Picture Master version
jonspurs
I don't think it does display every pixel at a given time (540 at one point), because it's ALiS. I think it 'supports' or 'accepts' a 1080p signal, but displays it as 1080i.
Jon
bankroot
Jon
I think so.
Just tell me, why 42PD9700 does not accept 1080p signal ?
Where is the clue ?
jonspurs
I think so.
Where is the clue ?
Maybe at the time, there wasn't a standard in place.
Here are emails sent/received quite a while ago (May 2006) asking whether the 9700 could accept a 1080p source:
To Hitachi Digital Media,
Thanks for your reply. I've looked through the brochure and it only states 1080 as an input signal - but does not include p (progressive) or i (interlaced). I understand the 9700 can natively display 1080i, but am still confused to whether this model will accept a 1080p source.
Thanks Again For Your Time.
They replied:
No, there is no official standard written for 1920x1080p by EICTA the HD Broadcast standards organisation. The only HD Standards that exist are 720p50/60 and 1080i50/60.
This years model the 42PD9700 will be 1024x1080.
Image differences in 1080i and 1080p, to the naked eye, would not be noticable.
1080p does not have more lines than 1080i. Simply put, 1080p displays all 1080 lines at the same instance where as 1080i takes the odd lines then the even lines and displays them to display the full 1080 lines.
It doesn't really matter if the 9700 could/couldn't accept 1080p, as you can select a supported output format on the HD device.
Jon
camorra
The Picture Master chip doesn't interfere in any way with display processing, and the same happens in a 42PD8600/8700 (no picture master here) as in a 42PD9700 ;) Feeding a progressive signal gets a better picture, for both :D
A progressive signal does'nt mean that the picture is there as if you are looking at a painting In a progressive signal the data is sent a whole lot to the screen at a certain frequency, say 60hz :) In an interlaced system the picture is sent in two parts ;) In Alis first you have the even horiz axis illuminated and then the odd horiz axis illuminated at 120Hz (if i'm not mistaken) :eek:
Please don't start the Alis debate again, but you can try it yourself trying a DVD first with an Interlaced signal then with a progressiove one on a 9700 :smashin:
As regards 1080p with the 9700 and 8600/8700 Hitachi have omitted this input for their own reasons :cool: Next 42" panel will surely be a 1920 x 1080 Alis panel and accepting 1080P too....as, after all, the new P50T01, with a 1280 x 1080 Alis panel and accepting 1080P :clap:
Cheers :hiya:
bankroot
just tell me how is it possible ???
It is "your own eyes" evaluation, I suppouse.
If we feed 1080i and 1080p signal to device which can display only interlaced picture, it won't be possible to see any difference.
interesting sentence. I have to remember it.
I think, you have made mistake. number of frames is different (50/60 fps for 1080p, 25/30 for 1080i).
Frequency of half-pictures is 50/60 Hz in interlaced displaying.
Why DVD ?
Does it produce 1080 signal ?
I still think, that 1080p in ALiS panel is cheating.
sorry for my English.
choddo2006
If it really does refresh at 120Hz then each 60th, you're getting 2 lines from a single original frame lit instead of 1 line from a field then 1 line of guesswork.
bankroot
OK, but this is still INTERLACING.
Doesn't matter how fast will it be refreshed, 540 electrodes can lit only 540 horizontal pixels in the same time, no more.
A
arikhard
I believe that it doesn't refresh at 120 Hz; at least this was the case with the older Alis displays with 1024 lines (look here) and I don't belive that refresh method is changed for new models like P50T01 using 1080 lines. However, P50T01 is very promising display and I really wait first reviews. Also must hope that quality control is better in the new plant in Czech Republic than it was in Turkey.
bankroot
Mathematically that's correct, but subjectively your eyes would see a sharp 1080 picture, not 2 x 540 images jumping up and down.
Jon
I know it.
This is why ALiS panel can display 1080i using only 540 electrodes.
But only 1080i, not progresive.
In progressive method panel display full frames with 25/30 Hz frequency.
How we can display full frame (lit all pixels) in ALiS panel ???
Problem is, that I cannot imagine myself, how it is possible.
If somebody knows, please share this knowledge with me (if you think not worth to write it here - send me private email)
cheers
bankroot
I checked many 9700 series devices, so I have never seen (in Poland) Made or Assembled in Turkey sticks.
All plasmas were made in Czech Republic.
I Poland version C and N is being sold.
Maybe U version is Made in Turkey ?
camorra
Panels were always made in Japan at the FHP plant, apart now from the Czech-made 50" I guess ;) Assembly only, of some models took place on Turkey :eek: Surely the 6600 was one of them :thumbsdow
All in all if you peep through the ventilation holes on any Hitachi model you can notice the panel factory information on the upper right side, looking from behind :D
Cheers :hiya:
12 promises
does this help/hinderthe discussion?:)
12 promises
Cheers :hiya:
having had a "peep" through the vent holes of my p50t01u set the label on the left hand side says "FUJITSU HITACHI PLASMA PANEL DISPLAY LIMITED" and "MADE IN JAPAN".
on the same label id is the serial number.
on the right hand side there is an electronic part which is etched "MADE IN JAPAN".
there are various other labels with barcodes etc but nowhere else is there any reference to Czech Republic, Turkey or another country to be found.
the outer box has no indication whatsoever of a country of origin or assembly.
if my memory serves me correctly the Hitachi website states that the Czech plant would be operating in the summer of 2007 so it is unlikely that the set was made/assembled there.
this is a Japanese made/assembled set.:)
Latest News
Google launches Pixel 6 and 6 Pro smartphones
  • By Andy Bassett
  • Published
Sony announces two new 3LCD laser projectors
  • By Andy Bassett
  • Published
Ruark Audio R5 is Made In England collection launch product
  • By Andy Bassett
  • Published
Apple unveils MacBook Pros for 2021
  • By Andy Bassett
  • Published
Apple launches third generation AirPods with spatial audio
  • By Andy Bassett
  • Published
