Hitachi HDB60 Freeview
john9159
I can't use my freeview receiver on my Panasonic TV as it only has a coax socket and no SCART socket. Can anyone suggest a cure? I like this set as it has better sound quality than my other TV which incidentally does have a SCART so my freeview receiver does work ok. Would appreciate some advice. Thanks.
sdc395
If you have a VCR that you use with this TV, you could try connecting the Freeview box to the VCR's input SCART, then switch the VCR to the SCART input and it should modulate the Freeview box's output for you.
Alternatively, buy a dedicated modulator such as this one.
