Hitachi DV-P305
Discussion in 'Blu-ray & DVD Players & Recorders' started by keithdw, May 31, 2001.
  1. keithdw
    keithdw
    Feb 13, 2001
    3
    Wrexham, United Kingdom
    I have a Hitachi DV-P305 and am looking for a region hack. the hack posted on this site for the Hitachi DV-P305e does not appear to work.
    Has anybody had any success in hacking this model? :confused:
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Use the same hack as for the samsung 709.
    I have used it successfully.
    With the player switched on, tray closed and with no disc in:
    Press and hold 'Play' and 'Stop' until Langauge menu is displayed.
    Select '1' for English
    Press 'Repeat'
    Carefully enter 3,8,7,6,7
    Youl will see '02' appears in left hand corner of screen. This is your current region.
    Imediately press '9' (this selects all region play)
    09 should appear, if you've done the button pressing correctly.
    Now press 'Open' on the player, followed by 'Standby' on the unit.
    You are now multi region and shouldn't ever have to do this again.
    NB: The 'Repeat' button is the normal repeat button and not the AB repeat.
  3. BEN ZANNINI
    BEN ZANNINI
    May 8, 2009
    2
    i tried your suggestion using the samsung 709 as you outlined
    however after entering the 3,8,7,6,7 digits the 02 does not appear and after entering the 9 i do get the 09 however
    the dvd does not read the disc ( which is english from england). What can i do now?? Can you advise? I followed your instructions several times with no luck.
