hitachi dv-p250e multi-region urgent!!!
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by crakh3d, Aug 4, 2005.
  1. crakh3d
    crakh3d
    hi i really need some help, anyone know how i can get my hitachi dv-p250e dvd player 2 play region 1 dvds,infact be multi-region.when i bought it i was told it was multi region but it seems 2 play everything except region 1.ive lookd at the remote handset hacks, but they're not working.please help .thanks in advance
  2. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Only way to mod this machine is via a couple of factory service discs. As its a old machine not many dealers ofer mods for it now. Either way a google search for your model and multi region should help.
  3. crakh3d
    crakh3d
    what about these handset hacks on this on many other websites? ive tried them but i dont even get the first 'languages' menu that is supposed 2 come up? also i did i search but cant find the factory service discs, anymore ideas or points in the right direction. thanks in advance.
    also i have a sony home cinema sav800 system, which also plays malaysian vcds, but wont play my region 1 dvd.any ideas on that system? thanks
  4. Justin@UH
    Justin@UH
    Feb 21, 2002
    2,192
    63
    +93
    As per earlier post, handset hacks only work on the intended model, they won`t work on machines / brands that need a physical mod such as a factory remote, pc interfact, or firmware disc.
