Hitachi DV-P250E, DV-305E, DV-315E & DV-P515E multiregion hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Stuart Wright, May 22, 2005.
  1. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,937
    2
    167
    Birmingham, UK
    +9,671
    There are 2 possible hacks which should malke the player work. Hack 1 goes like this:
    * Always perform a Cold Start before applying the hack
    * Power On
    * whilst pressing hold both the Play and Stop buttons on the front player After a short while you should be presented with a set of language options.
    * Release the Play and Stop buttons on the player
    * You will now need to select a language option between 1 and 6
    Hack 2 goes like this:
    * Press the Repeat button on the remote control
    * Using the Remote enter the code below, note that you must know what Region your player is currently set to in order to know which code is appropriate
    o for Region 1 use 2, 9, 3, 3 and 4
    o for Region 2 use 3, 8, 7, 6 and 7
    o for Region 3 use 5, 6, 7, 3 and 2
    o for Region 4 use 7, 6, 8, 8 and 4
    o for Region 5 use 5, 3, 8, 1 and 4
    o for Region 6 use 2, 4, 4, 6 and 2
    * A code should be displayed on the screen indicating the current region setting of your unit
    * Press the 9 button on the Remote Control for Region free, or 1 for region 1, 2 for region 2 and so on
    * Press the Open button on your player
    * Press the Standby button on the remote control
    If the player sticks on FBI warning screens press Forward Search x2 or faster and the disc should skip straight to the movie.
