Hitachi dp7200 - How many component inputs?
TommySplendour
Does anyone know how many component inputs the Hitachi dp7200 has?
I would like to connect both my Xbox 360 and PS2 via component.
Many thanks in advance,
Regards,
T Splendour.
camorra
One component input
You can connect the XBOX360 to DVI and PS2 to component :D
Hope this helps :hiya:
Spoonhead
Is there an Xbox lead with a DVI output? I thought it was component, scart or VGA that's available.
Have tried the VGA cable, but component wins hands down on my set-up
Gazza
S
syntax error
Gazza
Yip, you are right. Also just one component input. You will need to get a component switcher to make life easier for you.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
