Hitachi Deskstar jumpers - help!!
Discussion in 'Desktop & Laptop Computers Forum' started by witters, Jul 7, 2005.
  1. witters
    witters
    Jul 13, 2000
    11,981
    Yorkshire
    +263
    I have just bought one of these and can get it to run OK as a slave. I cannot get it to run as a master no matter what I do with the jumpers.
    Can anybody please help - I'm at my wit's end :D
    Model No. HDS722516VLAT80 160GB
    TIA
  2. DaveP
    DaveP
  3. witters
    witters
    Jul 13, 2000
    11,981
    Yorkshire
    +263
    Yes I have smart***** :D I have already seen that page but it does not work with those positions.
  4. DaveP
    DaveP
    In that case, and assuming the other drive is set to slave, I fear you have a faulty drive!
    Presumably you have tried CS? Also, presumably, you are running two disks on the same channel and not running the deskstar on it's own? Does it work on it's own? Is the other disk also a deskstar?
    Dave
  5. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    What system are you rtying to run this in, and what type of cable is it connected to?
  6. witters
    witters
    Jul 13, 2000
    11,981
    Yorkshire
    +263
    I am trying to run it on it's own. The existing disc was going to be used on another system. It works fine as a slave with the original disc as master but won't work on it's own as a master.
    It's being run via a primary/secondary cable on windows XP.
    Not sure what you mean by CS Dave?
  7. DaveP
    DaveP
    CS = Cable Select. With this setting you let the cable decide whether the drive is a Master or Slave. If you attach it to the end of the ribbon cable it will be configured as master and as a slave if you attach to the middle connector.
    I have had one drive that had to have no jumpers connected if it was a single drive. It was different if it was the master of two.
    Dave
  8. witters
    witters
    Jul 13, 2000
    11,981
    Yorkshire
    +263
    Thanks Dave - I'd alreay tried that without success. Looks like the disc is faulty.
    Thanks for all your help.
    Much appreciated.
