Hitachi CP-X275 and 325
Discussion in 'Plasma TVs' started by johnr2000, Mar 19, 2003.
  1. johnr2000
    johnr2000
    Mar 19, 2003
    20
    Please can anyone out there tell me how to reset the lamp timer to get rid of the lamp time warning message on these Hitachi projectors after the lamp's been changed. The original supplier is no longer around and Hitachi UK won't help because I'm not a dealer!!
    I seem to remember it's something like pressing two or three particular buttons in sequence after pluging the mains in - but before powering up.
    Many thanks. Johnr2000
  2. MRW
    MRW
    Aug 8, 2002
    238
    High Wycombe, Bucks
    +3
    Hi John,
    Matthew at Digital Message here - just happened to be browsing the forums at lunchtime and stumbled upon your post!
    You have in fact posted it in the wrong category - this should go in the category of:
    Video Projectors - LCD, DLP and other non-CRT technologies
    I'm not sure if you can get it moved to the correct category now.
    As I am a member of these forums, I have posted a message into the above category anyway to see if between us, we can get the answer!
    Best of luck!
    Matthew
