Hitachi CL32PD2100 input box help.
Discussion in 'Plasma TVs Forum' started by Mr Dead, Oct 16, 2004.
  1. Mr Dead
    Mr Dead
    I will appologise in advance for asking this question as im sure it has been asked many times before. I have just purchased a brand new Hitachi CL32PD2100 32 inch Plasma Display new for £400, the catch being there is no multi media box with it. I have priced up this part which costs £434.75 is there an alternative?
    It apears to have a DVI-D connector on the bottom of the screen would I be able to connect this direct to a pc with a DVI-I on the graphics card.
    Are then any generic boards/adaptors available (have had a good look with no success) I only require 1 scart input but any other input would do.
  2. ve003
    ve003
    did you find a cheaper AVC for the plasma screen? i think the conector is a Dfp,hpcn26,i too have a display but no multimeadia box!
  3. jonny_kay
    jonny_kay
    :lease:
    I was just wondering where to purchase the multi media box from as the shops do not sell them separately.
    Also, is there anyway you can connect a lead directly to from a pc or normal dvi reciver to the hitachi plasma screen itself without it going through the multi media box?
    :smashin:
  4. crashzero
    crashzero
    Jun 3, 2007
    22
    3
    ive got the same problem , has anyone got it workin ?
    or maybe got a cheap alternative or summin ...
    please help
  5. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    I need one too!!! I've contacted an Hitatchi service center they no longer supply the product....:thumbsdow:mad:
  6. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    I'm still looking for one of these boxes without any luck!!
    I have emailed Hitachi but they don't reply, it seems to me that the manufacturers are only interested in current models!! NOT GOOD!!
    :suicide:
