Hitachi Camcorder & Editing
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by redbrian, Oct 31, 2005.
  1. redbrian
    redbrian
    I have an Hitachi digital camcorder which recorders on 8cm. DVD-R discs. These discs won't play in the DVD player attached to my TV. How can I convert these these discs to 12 cm. discs to play in the DVD player. I already have a DVD burner attached to my PC.
  2. Brian110507
    Brian110507
    The discs should play in most stand alone DVD players but you may have to 'finalise' them in your camcorder first, - have you tried playing them on your PC - you will need some software which simulates a DVD player on your PC - you may have 'Power DVD' which is supplied free on some PCs.
    You can also import it to your computer in different ways and edit it, one programme you could use is Ulead VideoStudio you can get a free one month trial from here :-
    http://www.ulead.co.uk/vs/trial.htm
    you just put the DVD in your PC DVD tray and use 'import DVD' in the programme to transfer your video for editing and burning to a full size DVD - but again you may have to 'finalise' the DVD in your camcorder for it to work.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,618
    Rainham Essex
    +2,547
    Another thing to mention is that not all DVD players will play some or all recordable discs. What is your player? I normally check what a player can or can't read on This site.
    Mark.
  4. redbrian
    redbrian
    The disks play Ok on my PC. Thanks for the advice - I'll give these a go.
