hitachi c32wf523n - buzz
Discussion in 'General TV Discussions Forum' started by thunder11, Apr 7, 2001.
  1. thunder11
    thunder11
    wonder if anyone has had similar problems... my hitachi c32wf523n started to buzz loudly - a tube problem apparently (after only four months!). The tube has been replaced under warranty, but I still get an buzz from the tube ..noticeable during quiet moments etc.. its difficult to get an objective view on this from both the retailer and the repair shop.. should I expect some 'buzz' .. anyone?
    thanks.
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    Depends how well the tube has been constructed.
    The scan coils which wrap around the neck of the tube can vibrate, causing a buzz. The problem is that, most probably, they are encased in a plastic (non removable) cover. So the answer is to change the tube and (hopefully) get some better wound coils. But obviously, another tube with coils could do exactly the same thing.
    One thing I found on newer Hitachi sets, (how old is yours?), is that there is a spring attached from the line output transformer to a heatsink inside the set. Now that can vibtrate in sympathy with the transformer, (idiotic design!!), and it can seem like coils buzzing! The cure was to plonk resin on it to prevent vibration/buzz.
    The only way to know is in the wksp and see if they can prove that by soak testing, ie, leave the set on with the back off and watch the TV to see when it buzzes. Then simply touch the spring with a non conductive screwdriver handle to hold it still, and the buzz should stop (if it's that).
    good luck as I wouldn't put up with a buzzing TV!!!!!!
  3. thunder11
    thunder11
    cheers General! - the TV is only four months old and the new tube is 2 days old! hmmmm I wonder if the problem is as you suggest.. I will have to do some digging. If not, then just how many tubes will I have to go through before I get one which doesn't blinkin' buzz!!!
  4. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    I dont mean to sound silly but is the noise really a buzzing or more of a high pitched beep?
  5. thunder11
    thunder11
    Ironduke, its a Buzz. Strangly it sometimes changes pitch depending on the picture on screen (frequency?) We also have a Toshiba TV.. If you put your ear right next to the vents in the side of this TV I can also hear a buzz.. but its very faint, so I guess all TVs make some noise. Unfortunatly the buzz from the Hitachi can be heard from the other side of the room!
  6. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    Unfortunately, I've seen Hitachi sets go through a few tubes for this and other reasons.
    The Hitachi service rep was round our wksp a week or two ago, and there are mods apparantley for various tube related problems, but more purity problems I think, didn't really listen to him.
    I can only suggest you hassle your dealer 'a lot' to get it sorted, especially if it's that loud.
  7. anephric
    anephric
    Mar 23, 2002
    1,048
    Derby
    +147
    I've got this model and it buzzes quite loudly!
    I got an engineer round and he said there was nothing to be done, it was as per spec for the model and the coils were non-replaceable and integral.
    I fussed but they said nothing could be done, so i'm resigned to listening to things with the volume up!
    regards,
    anephric
