Hitachi c28wf560n - Reset back to default?
Discussion in 'General TV Discussions Forum' started by Escape-To-88, Sep 12, 2007.
  1. Escape-To-88
    Escape-To-88
    Been fiddling with the image setting in the service menu on my Hitachi c28wf560n and the picture looks a bit 'fish-eye' lens :(
    Wondered if there's a way to reset to defaults?? Have checked the users manual and can find nothing.
    thanks
  2. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    There isn't...this model has 140 odd adjustments for picture geometry and each has to be setup individually on each aspect ratio setting...they interact with each other...a widescreen pattern generator is needed to set it up correctly.
    I take it you didn't take note of the settings before you adjusted anything? :lesson:
  3. Escape-To-88
    Escape-To-88
    I see...
    Ah it doesnt look too bad now - yeah i did take note of all the numbers before - i'm just being lazy :)
    also it wasn't that well set-up before to be honest. Oh well no worries. Cheers for the reply
    *EDIT*
    I don't suppose you know, or know where i can get a list of what each setting does by any chance do you?
    cheers again
  4. oxman
    oxman
    Jun 2, 2006
    284
    +14
    how do you get the service menu m8
  5. oxman
    oxman
    Jun 2, 2006
    284
    +14
    to get service menu press menu then 4,7,2,5.anyone know how to get test pattern on screen
  6. BillyBoyBean
    BillyBoyBean
    Escape-to-88,
    Did you find out what each setting does or find out the defaults the set is dispatched with?
    Billy
