Hitachi 7200 removing swivel stand for all mounting
Discussion in 'Home Cinema Buying & Building' started by RhinoBanga, Sep 19, 2005.
  1. RhinoBanga
    RhinoBanga
    Aug 16, 2005
    Hi All,
    I have just taken delivery of my 7200 and I am going to wall mount it.
    One thing I am not sure of though is how to disconnect the unit from the swivel stand?
    There were two bolts on the back which seemed to connect the monitor to the stand. I removed those and tried to lift the unit but it was still connected.
    Can someone point me in the right direction please.
    Regards,
    Rhino.
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    Spaghetti Junction (really)
    +1,921
    I was going to say look in the manual, but it doesn't mention it.
    Which makes me think it should be straightforward.
    I would guess there is a spline or slot type of setup.
    Have you tried actually pulling the monitor off the stand? ie hold the stand whilst lifting the screen.
  3. RhinoBanga
    RhinoBanga
    Aug 16, 2005
    Hi Badger, thanks for responding.
    Yes I have tried holding down the stand while lifting the monitor vertically. It didn't budge. That's why I am assuming there is something I am missing but I don't know what!
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    +1,921
    Sorry I can't help mate.
    But I'm sure someone will :smashin:
  5. bluecupra
    bluecupra
    Hello,
    I own a 7200 and have it wallmounted. The swivel is attached to the screen with 4 bolts/screws (2 on each side of the swivel). Two are on the lower side of the screen (thumbscrews) and the other two have to be removed with an screwdriver. If the four bolts / screws are removed you can lift the screen of the swivel.
    You can't go wrong with it actually. It's strange that there's nothing in the manual of removing the swivel...
    If things ain't clear just ask
    Jeffrey
  6. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    +1,921
    Told you ;)
  7. bluecupra
    bluecupra
    at your service :rotfl: :smashin:
  8. RhinoBanga
    RhinoBanga
    Aug 16, 2005
    Thanks for all your help guys.
    I didn't see the additional bolts because I had attached part of the wallbracket to the back of the monitor which obscured them.
    It's now on the wall and it looks lovely :) :) :)
  9. Badger0-0
    Badger0-0
    May 30, 2005
    20,583
    +1,921
    Nice one :smashin:
    Give us your opinions on the screen mate (good or bad), when you got it sorted.
  10. RhinoBanga
    RhinoBanga
    Aug 16, 2005
    I was playing about with it last night and the PQ is superb. I was watching The Incredibles on my DMR-EH50 (via component set to progressive) and I was blown away with how much detail I can now see compared to my old Sony 36FS70.
    I also set my xbox to 1080i and XBMC and was amazed at how good it looked :D
    I chose the 7200 over the Panny PV500 due to a) stock issue and b) better connectivity and I am well happy with my decision.
  11. bluecupra
    bluecupra
    Welcome to the Hitachi 42PD7200 club :clap:
  12. StuBFrost
    StuBFrost
    Dec 20, 2004
    1,475
    48
    Manchester
    +71
    I have just bought a 7200 and a universal wall mount.
    Could you tell me where on the back of the TV I should be putting the brackets. I can see all sorts of screws but I wasn't sure which ones I should be using.
    Many thanks
    Stu
  13. RhinoBanga
    RhinoBanga
    Aug 16, 2005
    Did you get this sorted Stu? If not let me know and I'll take some digi camera pictures for you.
  14. StuBFrost
    StuBFrost
    Dec 20, 2004
    1,475
    48
    Manchester
    +71
    Hi RhinoBanga
    No, I haven't sorted this out yet.
    Some pictures would be very helpful.
    Stu
  15. RhinoBanga
    RhinoBanga
    Aug 16, 2005
    Try these:
    http://www.jdnet.co.uk/7200_rhs_wall.zip
    They should give you an idea where to put the right hand side bracket (when facing the front of the screen).
    Sorry they can't be better but it's pretty hard getting to the back of the unit.
  16. StuBFrost
    StuBFrost
    Dec 20, 2004
    1,475
    48
    Manchester
    +71
    Thanks for the pictures.
    I think I know which ones to use.
    Looking at my TV, am I right that there are 4 screws in a square and that none of them have arrows pointing at them. I can also see another set of 4 screws in a square but one of those does have an arrow so I presume that it is not that set.
    Stu
  17. RhinoBanga
    RhinoBanga
    Aug 16, 2005
    Hi Stu,
    Sorry I can't really see as I have my TV high above my fireplace and it's difficult to see anything.
