Hitachi 5200H
Discussion in 'Plasma TVs' started by Zebraman, Jun 13, 2005.
  1. Zebraman
    Zebraman
    Jun 13, 2005
    41
  2. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    what the fudge!
    That's a 42PD5200. Where has the H come from? has Hitachi added something extra to it to make it totally HD Ready?
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    This is an old model, and I see no difference between this and previous ones sold in the UK. Also the suffix letter denoted the tv's place of sale so a UK tv should be a 5200E. All of the Hitachi sets were touted as being 'higher definition' than other plasmas because of the number of pixels. It is a good price for what some of us would say is not a bad set but don't be fooled by the high definition tag.
  4. Zebraman
    Zebraman
    Jun 13, 2005
    41
    yep, they've made it HD ready but i'm wondoring where all the connections have come from as the standard 5200 only has 1 scart.
    unbeatable.co.uk have listed it as a new set coming soon.
  5. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    On closer inspection, they seem to have reworked its interface boards. 2 scarts and 2 DVI connectors.
  6. ereggiani
    ereggiani
    The key question is: does it now support 720p / 50 Hz ?
  7. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    So is this a 42PD5200 with some new bits on it? If so, is it possible to add bits to mine?
  8. Snap
    Snap
    Aug 7, 2005
    188
    Celle (Hannover)
    I see 1 scart, 2 DVI's and
    "Manufacturer Code: 42PD5200H
    Internal Product Code: HITACHI.42PD5200H"
    written below connectors pictures.
    I am looking for model similar to 5200H but selling in Germany....?
  9. cheetah69
    cheetah69
    they have this on sale in comet oldham for £1495 with i big sign HD READY i will go and look at it today :)
  10. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Does anyone know if it is possible to "convert" a standard 4200 to the HD ready model?
    This would be a better option for me as I really like my 4200 and don't want to have to get rid of it and buy a HD ready plasma!
  11. AndreiM
    AndreiM
    Here is a response from Hitachi on the H vs E models. I have the H and can confirm it does support 720p 50Hz though only via the DVI input.
    Dear Sir/Madam,
    Thank you for your email.
    The difference between the 5200E and the 5200H is as follows. The 5200 can accept 1080i @ 50 / 60 and 720p @60. The 5200H can also accept 720p @ 50 through the DVI input only. It is HD Compatible.
    I apologise for any inconvenience or dissatisfaction this matter may have caused you but trust that the above information has helped to clarify the situation.
    Regards
    Consumer Affairs Team
    Hitachi (Europe) Ltd
    England, UK.
  12. IanD912
    IanD912
    Thought some of you might find this interesting regarding the 5200 series.
    Recieved this email this morning from Hitachi. - Looks like good news (I hope!):thumbsup:
    Dear Sir,
    HDTV broadcast services will start in Europe in 2006. This will deliver viewers the best picture quality ever seen in the history of broadcast television. HDTV refers to the highest-resolution format of digital broadcast TV. While there is still some discussion about what is true HDTV, it is generally accepted that 1,080-line interlaced (1080i) or 720-line progressive (720p) are HDTV. A TV that is described as 'HDTV-ready' is usually capable of properly displaying at least 1000-line interlaced or 720-line progressive.
    32/42PD5200. These sets cannot be called "HD Ready" because to do this you need to be able to accept and display 1080i 50/60 & 720p50/60 via DVI and Component. We can show 1080i 50/60 but only 720p60.
    42PD5200H. Again we cannot call this set "HD Ready" but we are calling it HD Compatible. It can accept all signals via the DVI and all signals except 720p50 via component.
    32/42PD7200 Fully Compliant with "HD Ready" specifications.
    The Good News:
    Sky have confirmed that the first HD boxes will allow you to select the output, so you can select 1080i (which we think is the best signal anyway) and connect via the Component input. This means that you can view ALL sky programmes including HD broadcasts. It may also work via the DVI socket but this is a bit more complicated and we will need to see a Sky box before we can confirm.
    Regards
    England, UK.
  13. John
    John
    Dec 13, 2002
    10,968
    +2,659
    It is good news , but I've yet to see SKY confirm anything . I'll wait and see , for now
    John
    Ps , welcome to the forums
