Hitachi 42PMA400E Fan Noise
Discussion in 'Plasma TVs Forum' started by jmcarter, Aug 20, 2003.
  1. jmcarter
    jmcarter
    Jul 20, 2003
    23
    I have just purchased one of these plasmas, and am finding the fan noise a little distracting. I have plasterboard walls and laminate flooring which isn't helping i guess. Would it be possible to put some kind of sound dampening material behind the plasma, and if so, does anyone have any recommendations?
  2. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    Nexnix adviocate putting a thick towel behind the screen. I have some loose weave matting shoved in there at the moment but I can't decide whether it helps or not. To be honest I'm getting used to the noise now.
    I e-mailed a load of manufacturers of acoustic materials and the only repiesy I got back were from Soundreduction.co.uk whi suggested their Coustifoam product, and CustomAudioDesigns.co.uk who suggested their "black FR acoustic foam".
    However, if you do a search you will find a thread by me in here on an upcoming official Hitachi fan modification that should reduce the noise levels for this screen.
  3. jmcarter
    jmcarter
    Jul 20, 2003
    23
    Thanks Darren, I had come across your thread before - any ideas when the mod will be available?
  4. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    No idea at all I'm afraid. I'm out of the country for a week. When I come back I'll chase them up about it. They did imply that if they approved the change it would be very soon.
