Hitachi 42PM400E Scart input board
Discussion in 'Plasma TVs Forum' started by Weon, Aug 30, 2005.
  1. Weon
    Weon
    Feb 28, 2005
    33
    Cheltenham
    Can anyone tell me where/if I can get an RGB scart input board for my Hitachi 42PM400E, preferably to replace the RGB (PC Style) inputs that are in there currently?
  2. Weon
    Weon
    Feb 28, 2005
    33
    Cheltenham
    I guess that's a "no" then!
  3. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Hitachi do a media receiver AV3000E for their panels, including SCART input.
    Give Hitachi a ring to discuss.
  4. Clabs
    Clabs
    Nov 5, 2003
    135
    +7
    What equipment are you looking to plug into your plasma, Weon??
    Clabs
  5. Weon
    Weon
    Feb 28, 2005
    33
    Cheltenham
    stanleyntl - That looks good but it appears that the best non-SCART ouput it has is S-Video (Data Sheet (Scroll Down) ) which will not offer me any real improvement over my current setup!
    Clabs - The main driver is connection to my Sky box. For more detail see this thread
  6. Clabs
    Clabs
    Nov 5, 2003
    135
    +7
    Hi Weon - I used a SSSCRGBS cable for my SKY+ box into Video 2 input on the 42PMA400E. I was using a scart-component convertor, but found this method gave a marginally improved picture and allowed me to do away with the convertor.
    I was also using scart/component convertors for my xbox and dvd into the 15 D-subs but have used SS15D3P cables that once again do away with the need for the convertors.
    The cables were from Lektropack by the way.
    Cheers, Clabs
  7. Weon
    Weon
    Feb 28, 2005
    33
    Cheltenham
    Hmmmm. So theoretically I could use the SSSCRGBS to plug the Sky box into the plasma component (Vid 2). Then I would make a single 'lead' from the SS15D3P, 3 double-ended phono female adaptors and the Composite output cable from my PS2 to connect the PS2 to RGB (D-sub) on my plasma?
    When using the SSSCRGBS, do you just have a single plug hangin unused from the back of the screen? It has 4 phono plugs but composite only uses 3 :confused:
  8. Clabs
    Clabs
    Nov 5, 2003
    135
    +7
  9. Weon
    Weon
    Feb 28, 2005
    33
    Cheltenham
    Clabs - thanks for that thread. It was all going so well until I got to the part that said I can't use the s-video input on VIdeo 1 due to Video 2 using the Composite input for the sync signal. My Yamaha Amp/DVD only outputs s-video or composite (i'ts getting on a bit). Argh!
  10. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Hi Weon,
    The main output appears to be DVI + 3.5mm audio, on the media box. Any good to you? :thumbsup:
    The svideo/composite outs aren't for feeding a panel at all.
  11. Weon
    Weon
    Feb 28, 2005
    33
    Cheltenham
    DVI ain't much help as the closest thing I have is D-sub. Cheers anyway. It's getting to the stage where I might just give up. Too much hassle!
  12. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Weon,
    You perhaps ought to talk to Keene Electronics - see www.keene.co.uk, this is right up their street. They have various boxes, cables etc to convert video to DSUB for plasma connection.
    e.g. a SCART RGB -> DSUB cable, DVI -> DSUB box etc.
    Should be able to help you. :smashin:
