Hitachi 42PD7500 - No SKY RGB!!!
Discussion in 'Plasma TVs Forum' started by stanleyntl, Aug 24, 2005.
  1. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    First off I was annoyed that PRC Direct had this model listed as having 3 scarts, when it only has 2! :mad: :mad: Only the 42pd7200 has 3 scarts.
    Secondly despite, changing Pace box menu to RGB, the Hitachi still registers a composite signal, and for AV2 there's no way to tell it otherwise! :mad:
    Any ideas out there?
  2. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    move it to AV1?
  3. Sparky101
    Sparky101
    Nov 17, 2002
    283
    +18
    Are you using the right Scart output on the Sky box? One of them does RGB, the other only composite.
  4. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    on the sky box TV does RGB the VCR socket does not
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Sounds like the problem is the scart at the plasma end, it's normal to find only 1 RGB scart out of 2. The system needs careful planning if you have several RGB devices, maybe a scart switch would help?
  6. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Will check leads on SKY box, they were correct when I last checked, but could have been monkeyed with by parents!
    AV1 is definitely composite/svideo which is what SVHS VCR is hooked up to (outputting svideo). (RGB sockets will only take RGB or composite).
    Manual for pd7500 states AV2 is RGB.
  7. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    have you used the scart cable for RGB before? is it a fully wired lead?
  8. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Yes I have, and it is fully wired. Will report back after swapping connections over.
  9. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Have double checked scart leads (SKY TV out -> AV2 (Hitachi)), and menu is set for RGB - still flagging as composite - plus no change in picture over PAL. :mad:
    In TV menu - Video input only has settings for AV1 and AV3 - not AV2.
    Scart lead is fully connected and RGB was available into old Sony Wega CRT TV.
  10. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Does your Pace box do Svideo via scart? If it does tell it to output Svideo and see if the plasma responds. It is not unusual for scart inputs to be composite/RGB or composite/Svideo. Not both. If the plasma responds then that is the best you will get into Scart 2.
  11. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No Pace sky boxes do s-video on scart, can't be that. I think there is a fault in the plasma. It appears in the manual you have to select RGB for AV2 in the setup. If you have done this and there is no difference between PAL and RGB, then the plasma is not picking up RGB, simple. If you set a Pioneer for RGB you get no picture with composite (pal). It sounds useless, but then you can tell exactly what is going on.
  12. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Hi MAW, looked at setup - i.e. video input - only lists AV1 and AV3 - no AV2!!!!
    Whether this is just my set - the pd7500 I can't say - proper bonkers. :mad:
  13. mjm2705
    mjm2705
    Jan 3, 2005
    274
    Aberdeen, Scotland
    +19
    My PD7200 accepts RGB on AV2 & AV3 SCART .. not AV1 !!
  14. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    pd7200 has 3 scarts (2 rgb), pd7500 2 scarts (1 rgb) - or no rgb in my case! :lesson:
  15. paulkelly111
    paulkelly111
    I have a 7500 and am using sky plugged into my home theatre box and then an RGB scart into av2 and it comes up RGB on the screen. I also have a component connection from the home theatre to tv. In reality the component leads are abit superfluous as the picture quality is almost indistinguishable between them (went a bit over the top on leads as I was trying to solve lip sync issues). Any way, I'm no expert, but it sounds like your set up and not the plasma as I can't believe one set has RGB and another doesn't
  16. stanleyntl
    stanleyntl
    Dec 6, 2003
    809
    28
    Worthing, Sussex
    +44
    Turns out to be a faulty Pace box (2400), replaced with DS430N - apart from scart hiccup (everything red) - now sorted. :clap:
