Hitachi 42pd7200 settings Can anyone help ?
Discussion in 'Plasma TVs' started by jbsc00, May 5, 2005.
  1. jbsc00
    jbsc00
    I have just bought a 42pd7200 and wonder if anyone can suggest optimum settings.
    I have a Sky+ second generation and a Pioneer 575 dvd player.
    Connect the sky+ via RGB scart (reds currently too orangy !).
    I connect the Poineer DVD via analogue component cables.
    Thanks in advance.
  2. thedude
    thedude
    Oct 18, 2004
    8,782
    Swindon
    +1,654
    im sure under the advance settings it has options to change the R-G just go towards the G more,
    See if that clears it up
  3. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    I'd try fiddling with the colour temperature settings first, if that doesn't give you the results you need, then you can fine-tune the colour settings yourself in the bottom of the picture menu.
