Hitachi 42PD7200 Questions
Discussion in 'Plasma TVs Forum' started by acanning, Aug 16, 2005.
  1. acanning
    acanning
    Mar 11, 2002
    111
    16
    Hampshire
    Hello
    Just a few quick questions about the Hitachi 42pd7200 I am thinking of buying.
    1. Is it possible to set a default input when you first switch the tv on. I would like it to default to Sky. The Sagem I have always defaults to analogue tv which is annoying!
    2. How does the Hitachi deal with changing aspect ratios as you flick from one Sky channel to another. Does the auto mode deal with the changes effectively?
    3. Should I be concerned about screen-burn and buy an LCD?
    Any help would be much appreciated.
  2. neilios
    neilios
    Dec 18, 2004
    8,058
    Earth
    +3,969
    1.Defaults to av2
    2.Panoramic or full ,no problems
    3.I personally have found my screen excellent no burn in ,image retention at all even after bbc's bloody interactive service pops up when i fall asleep.
    Hope that helps and you enjoy your screen. :)
  3. acanning
    acanning
    Mar 11, 2002
    111
    16
    Hampshire
    Thanks Neilios
    Just to clarify, if I plug Sky through AV2 (I assume it is an RGB scart) then the tv will always display Sky when I turn it on.
    I'm grateful for your comments.
  4. neilios
    neilios
    Dec 18, 2004
    8,058
    Earth
    +3,969
    Yeah mine does ,when i turn it on in the morn av2 comes on auto. :)
  5. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    Turn the telly on and SKY comes straight on, NP (assuming you leave SKY on 24/7 like me).
    Turn Sky off, change mode, then back on, Sky automatically comes on, as does DVD (AV3) :thumbsup:
    Don't they all do that??? (I really don't know).
  6. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    You're right Badger, RGB sources will only auto-switch if they are powered.
    My PV500 has AV1 power up preference but it's useless because I'm not gonna leave my Sky+ box on 24/7 and it auto switches to AV1 when I turn it on anyway so I don't see the point in these AV preference settings on TV's
