Hi I already have a 42PD3000 which a relative is having off me and I would like to buy a 42PD7200 and hang it where my 42PD3000 is. The 3000 was hung on a PWT001 bracket. The place I bought my plasma from before (they also sell the 42PD7200) now list 2 wall brackets. They are a PWT002 and a PWT001. These forums make no mention of a PWT002 bracket. I bought my 3000 from FutureHome www.futurehomeuk.co.uk. The thing is that they say that the PWt002 is for the 7200 alone and the PWt001 is suitable for the 5200/5300 etc. Hence I'm a little concerned that I now need to order a new wall mount and risk problems when putting up another mount in the same place as the last one. I would like to order a PWt001 for my relative so that she can get the new wall mount fitted and then I can just swap the TVs when I get a 7200. Any advice is greatly appreciated. -Junpit
Hi, I,ve just fitted a pwt002 bracket in preperation for a 42pd7200 According to instructions it can be used with the 32" AND 42" OF 2100/ 3000/5000/7000 Series and PW1 and 32pd5200
