Hitachi 42PD7200 plasma - programming the remote
Discussion in 'Plasma TVs Forum' started by Sheffmax, Jan 5, 2007.
  1. Sheffmax
    Sheffmax
    Oct 7, 2006
    24
    Sheffield
    +9
    Been lurking for a while and must say that all the info on this great telly has been very useful.
    I'd like to be able to use the TV remote for controlling other boxes so is there a way to do it (they're not on the list in the manual)?
    I have an Inverto PVR and a Proline DVDR700 plus a VCR connected up and I'd like to reduce the number of remotes used. Is the only way to buy a universal one or is it possible to use the TV one?
    Thanks, in advance.
  2. Sheffmax
    Sheffmax
    Oct 7, 2006
    24
    Sheffield
    +9
    Since I wrote this plea I've bought a Philips DVDR3380 player/recorder and would like some help/hints on setting up the TV remote to control this machine.
    The example given in the manual is not very useful as each number given is 1 and it doesn't indicate which particular instance you should replace with a 6 for the Philips model.
