Hitachi 42PD6600 sky remote code
Discussion in 'Plasma TVs Forum' started by paulefox, Sep 21, 2005.
  1. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    does anyone have this
  2. vince31
    vince31
    Aug 27, 2005
    139
    Swindon
    +13
    According to my old SKY (Grundig) manual the code for Hitachi is 0145. Cant try it myself as my plasma dosent arrive until tomorrow!
  3. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    I ahve been told that this code does not work , anyone know of another
  4. woodster
    woodster
    The code 0145 does not work, it only turns the tv on and off using standby, nothing else.
    Need another code.........
  5. av2diefor
    av2diefor
  6. soultrader
    soultrader
    just to let you know that i tried every single 3 digit code on the 6600 - yes, right from 001 to 999 and none work
    im not going to do the same with 4 digit codes thank you so i bought an all in one and gave up
  7. ian1888ah
    ian1888ah
    Dec 17, 2005
    38
    So has anyone managed to get the sky control to work with the 6600?
  8. ginoworm
    ginoworm
    Aug 29, 2005
    1,253
    48
    +51
    Quick Bump to see if anyone has found the code yet???
  9. oxy
    oxy
    Dec 11, 2005
    188
    16
    Oxford
    it is 747 on the 7200
    press tv, then select and red together ,then 747, then select
  10. about87
    about87
    747 isnt working. Well, 747 half works... mute and power works, but volume doesnt.
    Anyone else have any suggestions?!
