Hitachi 42pd5300
Discussion in 'Plasma TVs Forum' started by andrew@weed3559, Aug 29, 2004.
  1. andrew@weed3559
    andrew@weed3559
    Can anyone give me advice on the following two plasma tvs
    hitachi42pd5300
    hitachi 42pd5200
    advantages and disadvantages of either?
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    The 5300 comes with a tuner box - you make all your connections (sky, console, dvd player etc) to it and a single cable runs from the box to the screen - you get 3 scarts, component and s-video on the tuner box).
    On the 5200 the connections are made directly to the screen (single scart and component I think), the panels themselves are exactly the same.
    I've got a 5300 and think it's a great screen for the money :thumbsup: but watch out for the the buzzing - plenty threads on here about that :rolleyes: .
    For similar money or less, you can get a Panny PW6, rated by many on here as about the best you can get for the price.
    HTH
    John
  3. andrew@weed3559
    andrew@weed3559
    I think I will buy the 5300
    thanks
  4. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Watch out for the fact that you cannot use the DVI connection on the 5300 since it is used by the external media box. The connection is free on the 5200.
    -Ian
  5. andrew@weed3559
    andrew@weed3559
    I dont really understand about the DVI connection.
    I intend connecting my SKY+ box and Panasonic DVD recorder via the 3 scarts
    Hopefully this will be fine ????
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    IMO, if you want to keep your screen for 2 or more years and want the opportunity to get the best out of your display, DVI input should be a consideration. A similar argument would have been had a few years back with component input over SCART.
  7. andrew@weed3559
    andrew@weed3559
    I do intend keeping it for more than 2 years and as said Idont really understand connections but hopefully I will get good results using a good quality scart.
    thanks
