Hitachi 42PD5300 & Sky remote control
Discussion in 'Plasma TVs Forum' started by Big Al, Jul 25, 2004.
  1. Big Al
    Big Al
    Jul 13, 2000
    247
    Sandhurst Berkshire UK
    I've just taken delivery of the 42PD5300 and now have a problem operating sky via remote control.
    All sky signals are sent, but are not being recieved by the digibox. If I turn the screen off, the remote commands work. Sometimes they will continue to work after the screen is switched back on and then stop working. All my other componants work correctly, including sky via a video sender in the bedroom.
    I presume this is infra red interferance from the 42PD5300, but is there any way of dealining with this problem?
    Big Al
  2. dUnKle
    dUnKle
    Jan 1, 2001
    15,473
    +2,381
    I have the 5200 and Sky+ and have no problems - Sky box is probably about 2dt below the TV
  3. Big Al
    Big Al
    Jul 13, 2000
    247
    Hi Duncan
    Thanks for the reply.
    Problem sorted I moved the digi box back approx 25mm and all works as it should.
    Sky's help line was useless on this matter, insisting that I had to enter the TVs model code into the sky remote, quoting that the remote will not operate the digi box with out it!!!
    Regards
    Big Al
  4. Yelpir
    Yelpir
    Jul 19, 2004
    17
    Sorry to dig this up but I also have a 5300 and Sky+, do you know the code to allow the sky remote to operate the Hitachi ?
    Yelpir
  5. Big Al
    Big Al
    Jul 13, 2000
    247
    You could try the codes at the back of the sky plus manual.
    Sky were unable to give any codes for the 42PD5300.
    Big Al
  6. Mac B
    Mac B
    I've just set up a Sky Remote to operate the pd5300 and the sequence on the remote was;-
    Press tv on the Remote
    Hold the select and red button simultaneously till the red light blinks twice
    Press tv again
    Key in 0145 - remote blinks twice.
    Press off and if the plasma switches off, press select - Remote blinks twice.
    If the Plasma doesnt switch off - press tv then the off button until it does and press select.
    That did it for me. It took a couple of trys and eventually did switch the plasma off on the first attempt with the off button.
    Mac B
