Hitachi 42PD5200H quick questions...
Discussion in 'General TV Discussions Forum' started by DRZpt, Aug 25, 2005.
  1. DRZpt
    DRZpt
    Hi all :) ,
    Just got a Hitachi 42PD5200H and am eager to try it with HDTV. Would very much apreciate help with some doubts:
    1) If I get the Quali-TV reciever to get HD1, how should I connect it to the TV? DVI? can I also use video component?
    2) By the way, with a reciever without DVI, what is the conection option that gives best quality?
    3) If I download HD clips to my PC (a notebook) how do I send them to the Hitachi given that the PC does not have DVI output?
    Thanks for your help :smashin: !
  2. Venom1924
    Venom1924
    Jul 23, 2005
    16
    i can help u with 2) Component will give u best quality if u dont have dvi/hdmi
    3) im sure the 5200 has a pc input u can use that to play ur hd clips.
    Patrick
