Hitachi 42PD5200 - newbie questions
Discussion in 'Plasma TVs Forum' started by Vix, Aug 13, 2004.
  1. Vix
    Vix
    Aug 13, 2004
    90
    11
    +3
    I have just ordered a Hitachi 42PD5200. I have read about the issues some users have had with colour and Duncan Wardle's suggestions for fixing them. I am otherwise a complete newbie when it comes to current av equipment, standards, connections etc.
    I have a couple of questions and should be grateful for any advice:
    1) The 42pd5200 has only one scart. What are the best connections to use for:
    a) standard Sky box
    b) vcr
    c) dvd player
    2) any recommendations for a dvd player having dvi-d output to take advantage of the Hitachi's input? Is it worth the extra cost?
    3) any recommendations for a dvd recorder. (And if there was one with dvi-d it would be a bonus!)
    Cheers all!
  2. townsejl
    townsejl
    Dec 12, 2002
    14
    Hiya mate.
    Just a quick bit of info about the 42PD5200. Although it only has one 'scart' input, the component input 2 on the unit can be switched to RGB. You would need a scart to component (RGBs) connector (which you can get from Keene Electronics for about 6 quid) and the six phono-phone leads to connect your equipment (R, G, B, video-out, audio L/R) but this would give you an extra scart input and the picture quality on this is just as good as the dedicated scart input.
    Hope you enjoy your new toy mate, I've had mine for about 3 weeks now and am well impressed - it's worth messing around with the settings a bit tho. It can mean the difference between a good picture and a stunning picture :thumbsup:
    Jamie.
