E
edinburgh160
hoping someone can clear this up, but when I link up the PannyS97 with HDMI-DVI cable I get 2 choices in the setup.
one is DVI-PC and the other one is DVI-STB (is this Set Top Box)
I was using the default DVI-PC and only noticed this recently as the manual is very vague. I know the plasme is HDCP compliant, would it be something to do with if you use a PC's (being non compliant).
Does anyone know the difference, or confirm which one to use ?
I noticed that the tweaking options where far more numerous in the STB mode and minimum options for tweaking in the DVIPC mode.
Sure I should be using the STB mode, which also has a great picture
Hope you can help.
thanks
Kenny
Hope you can help.
thanks
Kenny
