Hitachi 42PD5200 any good !
Discussion in 'Plasma TVs Forum' started by electricery, Jul 10, 2005.
  1. electricery
    electricery
    May 14, 2004
    25
    herts
    Going to purchase new plasma and have seen good reviews on the 5200 and some good prices but just wondered if anybody has had one up and running for a while and give me some info good or bad :lease:
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
  3. electricery
    electricery
    May 14, 2004
    25
    herts
    Thanks John :thumbsup:
    Have browsed through thread looks like no matter how good the magazines rate the plasmas (within reason) owners of all makes have the same old problems.
    :rolleyes:
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Most of all, unless it has the 'H' suffix it is not HD ready. And yes, all plasmas have one problem or another, occasionally lots of different ones! There is no 'reason' about magazine review ratings. At my son's speech day yesterday, we had Sir Trevor Macdonald pointing out the low trust ratings of journalists. He made a joke of it. I do wonder with the reviews sometimes whether they've actually plugged the thing in. Not specifically the Hitachi 5000 series, you have to take it all with a pinch of salt. Media box plasmas do consistently better in reviews than panel only types, could this be a connection issue? Any professional will tell you the media boxes are nothing but a hindrance.
  5. electricery
    electricery
    May 14, 2004
    25
    herts
    True but you still got to feed it with a tv signal be it through ntl, sky or free view and the best out put they give is rgb through scart.
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Something the reviewers could do with knowing, I suspect. After all, scart is only RGB if you tell it to be. And just because a screen has RGB capable scarts does not mean to say this is the best way to feed it a signal. It's more or less a concensus opinion that component video looks way better on 5000 series. There are a couple of freeview boxes that put this out from their scarts, only requiring the right lead to make a considerable difference to the picture. Otherwise you are stuck with an expensive converter. Quite a few have gone this route.
