Hitachi 42PD3000
Discussion in 'Plasma TVs Forum' started by Mack, Jun 24, 2004.
  1. Mack
    Mack
    I have brought an Xpert DVD maker USB2, which is a video, capture device for my PC & I have connected it up to either the Composite or S-VHS output on the multimedia box on the 42PD3000. Even though I am receiving sound from the sound input I am receiving no picture, whether I use the composite or S-VHS leads.
    I was told the correct setting for the signal should be PAL-I (Uk standard) but whatever setting I set the software on the PC to I still do not get a picture.
    Does anybody know what signal the multimedia box transmits? Has anybody used one of these USB capture devices & got it to work?
    Any help is appreciated.
    Regards.
