Hitachi 42pd3000 Tuner Box
Discussion in 'Plasma TVs' started by Arya, Jun 12, 2003.
  1. Arya
    Arya
    The tuner box for my Hitachi 42PD3000 makes a faint beeping noise when the set is switched off from the display. When the display is switched off using the standby button on the remote, the tuner box makes a faint, continuous and high pitch humming noise. You need to get close to the tuner box to hear these noises.
    I've had the tuner box replaced based on a Hitachi engineer's diagnosis that an alternator?? was loose but the noises persist on the new tuner box also.
    Other than that, everything is fine re. picture quality, sound, etc.
    Anyone else notice the same and what the source for these noises might be? Is it worth worrying about? :confused:
  2. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    I always switch off using the standby button, and when I do so there are a couple of quite loud "clicks" from the screen and tuner box. I've never heard the humming noise you mentioned, but will check again tonight...
  3. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    My AV box is completely silent in standby. The clicks appear to be power relays in the box. The box has to be disconnected from the mains to be powered down.
