Hitachi 42pd3000 Tuner Box Problem.
Discussion in 'Plasma TVs' started by Pollywoggle, Dec 30, 2004.
  1. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,442
    South Shropshire
    +81
    My plasma was one of the John Lewis Price match specials from a year ago and has been fantastic, no screenburn or snags of any kind despite heavy xbox use and it being treated like a normal TV.
    Just lately however an annoying problem has developed, if the plasma is turned off after watching a dvd or the xbox has been used, when it is switched on again the tuner box just clicks on and off without "waking" the screen up. The only way to get it all working is to wait several minutes untill it has clicked itself crazy and seems to reset itself or unplug everything and hope for the best.
    I have checked all plugs, cables etc to estabish that there are no loose connections.
    Have there been any reported problems with the tuner boxes on the pd423000?
  2. Niraj
    Niraj
    Have the same screen, bought around the same time as you, from John Lewis.
    Not had any trouble with it, so would think that a call to JL is in order, asking for an engineer to come out and have a look.
    Niraj
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I have a 42PD5300 with the same box and have had no problems. However, I have seen someone else complaining about this fault in an earlier posting, so it could be a potential problem.
  4. johndon
    johndon
    Feb 3, 2002
    1,928
    48
    +89
    I've had mine around 18 months now and mine did something like this once - the tuner would come out of standby but the panel wouldn't then the panel wouls come out of standby and the box went back into standby.
    After about 30 seconds, the two got back in sync and the panel operated as normal. It hasn't happened since though.
    John
  5. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,442
    South Shropshire
    +81
    Thanks for replies, johndon, you describe exactly the problem I am having, seems to be happening more often now, guess I will have to get the engineer out.
