Hitachi 42PD3000 Problem -Christmas advice please
Discussion in 'Plasma TVs Forum' started by Terry Hughes, Dec 22, 2004.
  1. Terry Hughes
    Terry Hughes
    I have a 42PD3000 which normally works great, until we turn it off, and straight back on. If we do this, the AV3000E MM box, clicks away, but doesn't select either an attached DVD, or SKY+ box, both switched on.
    42PD3000 works in test mode without AV3000E attached.
    From cold it works fine, and once on, stays on. Only goes wrong if we turn it off, change our minds, and turn it straight back on. Any advice please on:
    1. Whats wrong
    2. Where to get repaired.
    3. Service manual copy (AV3000E is my guess).
    4. Alternative to AV3000E
    Thanks and Merry Christmas... please help...
  2. Niraj
    Niraj
    Are the DVD and Sky+ connected via a SCART?? If they aren't then it won't automatically select them.
    What happens on the screen when you do the quick change of mind restart thing?
    Of course, you could also try:
    1) Not changing your mind so quickly
    2) Being a bit patient after changing your mind quickly
    That was just a bit of a laugh mate :):)
    Will try it out on mine to see if the same thing happens........
    Merry Xmas :smashin: :smashin:
    Niraj
  3. Terry Hughes
    Terry Hughes
    Thanks for the advice.
    Both on good quality scart cables, normally switch over when a device is powered up.
    Screen has normal waiting backlite appearance (powered but no picture).
    I am guessing a heat related issue. It's well vented.
  4. Terry Hughes
    Terry Hughes
    Does anyone have a circuit diagram or service manual for an AV3000E?
  5. JayCee
    JayCee
    Jan 20, 2004
    22,397
    Lanarkshire
    +2,345
    Why, what use is it going to be to you.......are you a repair technician?
  6. Terry Hughes
    Terry Hughes
    Actually an Engineer by trade although I don't practice it now.
    Do you know where I can find one?
    thanks, Terry
  7. hdeters
    hdeters
    Hi all, hi Terry,
    just registered after looking for a solution to exactly the problem Terry described. I own an 32PD3000E with an AV3000E.
    Is there any news Terry, what did you do?
    I bought my device 6 month ago, but unfortunately the dealer has closed.
    Any help is highly appreciated.
    Regards Hermann
  8. simon391088
    simon391088
    Jan 14, 2005
    15
    I bought a 42pd5300 a few months ago and had this problem. I sent it back and got a 42pd5200 instead.
    I spoke to Hitachi about the problem and it doesn't relate to one specific problem. When you switch it on it does some checks and if they fail it switches itself off and back on again. This can happen lots of time, so it might click away for minutes. The problem is normally (apparently) with the media box.
    If you bought it 6 months ago, I would suggest contacting Hitachi.
    HTH
    Simon
  9. hdeters
    hdeters
    Hi Simon,
    thanks for your reply, yes I think I should contact Hitachi for this.
    Thanks again and
    regards Hermann
  10. Terry Hughes
    Terry Hughes
    In January my warranty ran out, took to long to find a solution and it cost me £280 to get the power supply replaced. This is what causes the switching problem to occur. Be warned I believe it was a design fault, but Hitachi didn't view it like that.
  11. poggs
    poggs
    Jul 21, 2004
    648
    28
    +31
    Sorry for bringing this one up again! Does anyone know how to get the screen into this test mode. My TV has a flashing yellow light on the panel and a solid red light on the tuner box. Cant get the tv to power up so dont know whether its the box or the panel that gone. I have disconnected the tuner box but still get the flashing yellow light on the tv and it wont power up.
    Any ideas?
  12. JayCee
    JayCee
    Jan 20, 2004
    22,397
    Lanarkshire
    +2,345
    What's the model no of your TV? (Taken from the label on the rear)
  13. poggs
    poggs
    Jul 21, 2004
    648
    28
    +31
    42pd3000E
