Hitachi 42PD3000 - PC input or scaler??
Discussion in 'Plasma TVs' started by Pacha, Nov 18, 2004.
  1. Pacha
    Pacha
    Oct 29, 2002
    134
    Basically i want to improve the SKY pic quality on my plasma but am not sure how to approach this.
    1. Is there any benefit to be gained by getting a converter and runing my SKY signal into the PC input? Has anyone tried this?
    2. Has anyone experience of a scaler with this type of plasma? (Those that scorn ALIS panels please don't comment 'cos i've read it all before)
    3. Has anyone experience of using an RGB to Component converter with this type of plasma?
    Any comments from real experiences would be very welcome 'cos i'm really not sure where to start.
    Thanks in advance
    Pacha
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Could you say what it is about the picture that you want to improve ?
    If it's lacking in detail, you might be able to sharpen it, but this can cause problems in itself if overdone. One of the problems of having a bigger screen is that it highlights picture defects (or as a farmer would say "If you open the barn door wide enough, all the muck flies in") :zonked:
  3. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    I used to have a 42PD3000 (got a 5300 now) and I was quite impressed with the picture quality from my Sky+ box connected via RGB with a good quality shielded scart cable. The higher bit rate channels looked great. I guess that an external scaler may have imporved the picture but you then have possible issues with lip sync.
    John
