Hitachi 42PD3000 and computer connection
Discussion in 'Plasma TVs' started by bossc@, May 28, 2003.
  1. bossc@
    bossc@
    Dec 20, 2001
    1,106
    +237
    Will be taking delivery of this next week and will be rerouting all my existing cabling over the weekend. I'm wanting to cable from my PC as well but am unsure as to the cable required. I've downloaded the product manual and that states that I should use a TP-RGBVG to connect from the PC to the tuner box. Have had a quick look around but cant find any refernces to this.
    Has anyone connected theirs (stupid question I know!) and if so can you recommend a cable or possible place to get them from. I'm running DVI currently to an TFT screen and would need a cable of around 8-10 metres.:rolleyes:
  2. Darren Blake
    Darren Blake
    Apr 28, 2003
    620
    Norwich, UK.
    +15
    I think the tuner box that comes with the 42PD3000 has 2x "normal" 15 pin VGA sockets for monitor connection.
  3. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    The AV box has one standard 15 pin d-sub analogue RGB connector ie a standard monitor connector point. A good quality RGB lead such as you would use for a data projector will work. The picture fed by my PC at 1024x768 was superb when I tried it.
    The screen is connected to the box using a double lead one of whose connectors is the same as used by DVI, in another post someone quoted Hitachi as saying this connector is used in a non-standard way and cannot therefore accept a true DVI signal.
  4. bossc@
    bossc@
    Dec 20, 2001
    1,106
    +237
    Thanks for the replies guys. Now just need to source me a cable and I'll be ripping the room apart at the weekend:(
  5. garreth64
    garreth64
    Sep 14, 2002
    265
    Midlands
    +15
    Only got my 42PD3000 on the weekend and set it up last night with my PC, picture quality is impressive. My Mrs sells AV equipment for a living and she said it was one of the best displays she's seen :)
    Anyway, the point of the post is to say dont forget you will need an audio cable as well if you want sound to come out of the 42PD3000.
