Hitachi 42 Connections
Discussion in 'Plasma TVs Forum' started by john kelly, Jun 11, 2003.
  1. john kelly
    john kelly
    can anyone advise me, i have brought the monitor only hitachi 42 inch plasma.
    if you connect to the s-vhs and component connections, the diplay does not like this, is this because its in the same connections on video 1? any way round this?
    Also my piture qualty seems to have got worse a little, anyone got a good picture setup settings list.
    One thing, i have brought a new dvd player and using the composit it looks superb, what a difference.
    need a decent tv tuner any one got a good one that works, need teletext.
    :hiya:
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi John,
    Sorry I can't help you with your connection problems - maybe some other owners will be able to offer some advice. For an analogue tuner with teletext, the Pro V+ seems to have a good reputation. Check out http://www.av-sales.com/html/prov_plus.html Hope this helps.
    Steve
  3. Darren Blake
    Darren Blake
    Apr 28, 2003
    625
    Norwich, UK.
    +15
    If you are talking about the PMA400, then the same circuitry is used for the s-video and phono composite inputs so you can't use them both together. When you are using component I think it expects a sync signal through one of the the video 1 ports.
    Someone did post a complete set of setup values a while ago. A search on PMA400 should turn them up.
  4. zorg2000k
    zorg2000k
    Jun 5, 2003
    367
    +15
    Heres some setting from a earlier post. I have these set on my PMA400 all seems good.
    Zorg
    Contrast...................................35
    Brightness................................+3
    Colour......................................+2
    Tint..........................................-10
    Sharpness...............................+3
    The rest of the settings were left at Factory default
    Picture......................Normal
    Contrast mode ........Dynamic
    Black Stretch............Low
    LTI............................Low
    CTI...........................Low
    YNR..........................Low
    BNR..........................Low
    3d Comb..................On
    Film Mode................On
    Gamma....................2.2
    Line INTP.................Off
    Colour Temp............Cool
