hitachi 400e high definition
Discussion in 'Plasma TVs Forum' started by andya, Jul 23, 2003.
  1. andya
    andya
    Oct 25, 2002
    2,427
    48
    manchester
    +35
    hi saw some of these hdf files the quility was amazing but i saw them on a loewe mimo 3 inch tv im wandering if anyone has there comp hooked up to there hitachi plasma and whats the quility like.can only play them in microsoft media 9
  2. Damox
    Damox
    3" !!! anything would look clear (well through a microscope) on this.. do you mean 32"? LOL
    The Hitachi is meant to be HD compat so in theory it should be able to view those files with increased video quality..
  3. JH4
    JH4
    May 6, 2003
    2,402
    63
    +244
    Only way I have seen Hi Def is via a D-VHS D-Theater tape from the US - it was absolutely superb on the Hitachi 400E.
    Regards.
  4. andya
    andya
    Oct 25, 2002
    2,427
    48
    manchester
    +35
    here are links to all the hd stuff if youve got a fast connection
    Fusion Player >>> this is the best for showing off HD clips - Install this before downloading the HD clips.
    http://www.dvico.com/hdtv/download.asp
    Fusion HD Demo clips >>> its in Japanese so just click on each link at the bottom
    Note: you have to put the files into the FusionHDTVDemo folder or else it wont work.
    http://www.dvico.co.kr/Download/d_fusionhdtvdemo.asp
    This site is great for HD clips - he only has one clip at a time to download but changes them every 2-3 days so be sure to keep checking back.
    Note: You need a mpeg 2 player to watch these - one is on his site which you get from.
    http://206.159.116.24/public.htm
    HDTV Stills...
    http://www.feldoncentral.com/hdtv/
    Another HD download
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=171590&highli
    Scroll down to where its says HDTV samples, I think there is about 4 files get here. Note - I think with this one you have to right click on the files and save target as...(I think !!)
    http://www.heise.de/ct/ftp/spezial.shtml
  5. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,714
    2
    48
    +62
    The WMP9 clip is choppy on my XP2000,GF4 4200,512MB RAM machine.
    This is great info btw!
  6. andya
    andya
    Oct 25, 2002
    2,427
    48
    manchester
    +35
    use fusion player and you can change the resolution the quility is amazing.why in the uk are we so behind
