Hitachi 32W8DB menu advice needed
Discussion in 'General TV Discussions Forum' started by orgal, Jan 23, 2008.
  1. orgal
    orgal
    Jan 1, 2006
    630
    +4
    Does anyone know the buttons to press to get into the service menu for a Hitachi 32W8DB TV...
  2. JayCee
    JayCee
    Jan 20, 2004
    23,645
    Lanarkshire
    +2,554
    I suspect you've given the wrong make...there is no Hitachi with that model no.
    There is a Toshiba 32W8DB.
  3. orgal
    orgal
    Jan 1, 2006
    630
    +4
    cheers mate it is the Toshiba 32W8DB dont know what I was thinking...:suicide:...mods can you please change post from Hitachi 32W8DB to Toshiba 32W8DB...
  4. mechanic
    mechanic
    Nov 15, 2006
    289
    edinburgh
    +35
    I`m assuming you know what you are doing in entering the service mode as you can seriously mess up a set if you don`t.
    Press the mute button on the remote - press mute again - but this time hold it while pressing menu on the set. This will take you into the service setup menu.Channel +/- changes the function Vol +/- changes the values.Switching to s`by stores the settings.I always advise to scroll through the settings and take a note of them so you can always return to a known "good" setup.Good luck.
