Hitachi 32LXD7200. A quick query
Discussion in 'LCD & LED LCD TVs' started by Captain Kak, Jun 5, 2005.
  1. Captain Kak
    Captain Kak
    Feb 21, 2005
    27
    Just took delivery and like most folk very impressed with it. The only query I have is that when using my dvd player and I press the progressive scan button on the player, the screen splits in two and turns purple. It's ok when progressive scan is switched off. I am connecting my player via the scart on AV3. Any ideas how to fix this?
    Cheers. :smashin:
  2. JFKM
    JFKM
    May 29, 2005
    362
    Somerset
    +39
    I would have thought that progressive scan won't be available through a scart socket. You will need to connect your dvd via the component connection with a suitable lead, then progressive scan should be fine.
  3. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    progressive scan does not work through scart cables, it works only through component cables or HDMI/DVI cables.
    When you activate progressive on your dvd,rgbvia your scart is unable to handle the progressive scan signal and hence the strange display on yout tv.
    Get some components cable and enjoys beautiful prog scan images!
  4. Captain Kak
    Captain Kak
    Feb 21, 2005
    27
    Cheers guys :smashin:
